Old 03-31-2013, 11:49 AM   #33 (permalink)
myrefugeisintheLord
Learning Aeromodding
myrefugeisintheLord's Avatar
Metro - '93 Geo Metro 4 door hatchback
90 day: 35.26 mpg (US)
Thank you Bruce for pointing those things out! I TOTALLY forgot about using anti-seize!!! That would have made everything SO much easier! I'll see how things go with what I have. If I need to start over, that's fine. I can pick up a set of lug nuts for $1. And the inner nuts came to $2 something. I might also ask one of my sister's relatives if I can rent his drill press if I have to do everything over again.
With RAVadoodle, I didn't use spacers between cover and lug nuts. I'm using 1/2" hex bolts with a straight edge screw driver option. I got hex for the same reason. I also didn't want any possible stripping! Something that REALLY helped to get the covers on, is I used two 2" long bolts and got the cover in position, and then securing it with 1/2" was a breeze.
I REALLY want to have this mod done before I leave for Seattle on Wednesday morning! I don't have a lot things left to do before I go pick up my dad from the airport, so I think I will be able to get it done. As long as things go more smoothly! I'm going to be meeting Shorty_Boy over there (CRX owner), and it would be fun to have that mod done for that reason too.
