Old 03-31-2013, 01:51 PM   #9 (permalink)
jamesqf
Where do you drive that people behind you use their high beams? Nobody does that here.
Northern Nevada, mostly, but I think it's pretty much the same everywhere. A lot of newer SUVs & pickups don't even HAVE low beams any more, just high and higher, because they have two sets of headlights, one at normal level, and one 5-6 ft off the ground. Then there are the cars fitted with high-intensity lamps...
The Following User Says Thank You to jamesqf For This Useful Post:
Cobb (03-31-2013)
