Originally Posted by Cobb
Just 1 relay to 1 wire to kill the injectors? Id considered something like that for the insight, but we got 4 yellow/black wires and guessing 4 relays unless I want to do something fancy and make it a 2 cylinder.
The Xb has four black/ red stripe wires if you splice closer to engine. You could use two relays to do four wires If you use a DPDT relay, I'm only using half of the one I bought, If it ever wears out I can use the other side
