Old 03-31-2013, 11:22 PM   #7 (permalink)
teknicalissue
ok so my goal should be to maintain temps between 120 to 140... I think I will use the heat shield to warm the air since I can somewhat direct where the air flow is coming from (vacuum shape of the heat shield). There is also a hole at the bottom of the heat shield used as a resonator.. perhaps I'll cover 3/4 of the shield off and force air to be sucked from the resonator which will be pulled from the heat of the manifold..
Project time!
