Old 04-01-2013, 06:32 AM   #1 (permalink)
drmouse
Mice don't use much fuel
Hybrid motorcycle ideas
Hi all
I have been thinking about his, on and off, for a couple of years. I would like to make the simplest possible hybrid conversion for a motorcycle. This has not been my number one priority up till now, but I may be changing jobs soon and my VW Bora 1.9TDi will no longer be the the most suitable choice of transport. I would be driving through rush-hour inner-city traffic, which will tank the efficiency of my VW. This has brought the motorcycle mods back to the fore.
There are a couple of ideas I have had for this. My first idea was simply to add a small series-wound motor with a sprocket at the back, driving the chain. This could be driven from batteries (a small pack, it's mainly for crawling through traffic), or from the generator on the bike if/when it was more efficient than the engine directly driving the wheel.
The other idea struck me when I was reading up on the charging system on my bike. It uses a permanent magnet, three phase generator to supply electric power from the engine. This, in essence, is what an AC or BLDC motor is. So why couldn't I just use a BLDC motor controller hooked up to the generator windings (obviously without the regulator/rectifier)? It has some significant disadvantages (like only being able to drive through the engine) and it will not be the most efficient motor on the planet (I think the winding resistance is very high compared to real motors, although I may be wrong), but it is already there.
So, what do you all think? I am no expert, but from my rough calcs either should work and be pretty cheap to implement (apart from the battery pack). I welcome any ideas or constructive criticism (or even an expert telling me I'm an idiot )
