Old 04-02-2013, 07:37 PM   #642 (permalink)
redneck
According to CAGW theory, CO2 is the cause of global warming...
Well, according to NASA, it's not. In fact, it has just the opposite effect.
Solar Storm Dumps Gigawatts into Earth's Upper Atmosphere - NASA Science
March 22, 2012: A recent flurry of eruptions on the sun did more than spark pretty auroras around the poles. NASA-funded researchers say the solar storms of March 8th through 10th dumped enough energy in Earth’s upper atmosphere to power every residence in New York City for two years.
“This was the biggest dose of heat we’ve received from a solar storm since 2005,” says Martin Mlynczak of NASA Langley Research Center. “It was a big event, and shows how solar activity can directly affect our planet.”
Mlynczak is the associate principal investigator for the SABER instrument onboard NASA’s TIMED satellite. SABER monitors infrared emissions from Earth’s upper atmosphere, in particular from carbon dioxide (CO2) and nitric oxide (NO), two substances that play a key role in the energy balance of air hundreds of km above our planet’s surface.
“Carbon dioxide and nitric oxide are natural thermostats,” explains James Russell of Hampton University, SABER’s principal investigator. “When the upper atmosphere (or ‘thermosphere’) heats up, these molecules try as hard as they can to shed that heat back into space.”
That’s what happened on March 8th when a coronal mass ejection (CME) propelled in our direction by an X5-class solar flare hit Earth’s magnetic field. (On the “Richter Scale of Solar Flares,” X-class flares are the most powerful kind.) Energetic particles rained down on the upper atmosphere, depositing their energy where they hit. The action produced spectacular auroras around the poles and significant1 upper atmospheric heating all around the globe.
“The thermosphere lit up like a Christmas tree,” says Russell. “It began to glow intensely at infrared wavelengths as the thermostat effect kicked in.”
For the three day period, March 8th through 10th, the thermosphere absorbed 26 billion kWh of energy. Infrared radiation from CO2 and NO, the two most efficient coolants in the thermosphere, re-radiated 95% of that total back into space.
The effects of space weather on our planet's climate are just now starting to be understood.
At the very least, information like this should give pause to the CAGW theory.
Pointing a finger at any one cause of climate change is not only irresponsible,
it could be downright dangerous.
freebeard (04-03-2013)
