Old 04-03-2013, 01:24 AM   #10 (permalink)
cRiPpLe_rOoStEr
One of the easiest Diesels to swap into the Metro would be the Briggs, which is actually a Daihatsu engine and was a factory option for the Daihatsu Charade in some markets during the 80s and early 90s, but as I quoted before, it would be hard to get the Metro registered after the swap due to the year of manufacturing and OBD-2 compliance.
Originally Posted by Ryland View Post
a VW engine is not going to fit, at least not from any VW's that were sold in the USA and VW put the smallest diesel engines in any diesel car in the USA so you are going to have to go with something from a very small tractor or generator, then you are still going to need the offset transmission that you'd get in a car with the larger 4 cylinder engine
It's not exactly impossible to fit a VW Diesel into a Metro. Some versions of the Suzuki Swift sedan even had a 16-valve 1.6L gasser, not to get into other engine swaps with Opel 2.0L gassers and the Peugeot 1.9L XUD9 Diesel...
