Old 04-03-2013, 11:30 AM   #18 (permalink)
Daox
Another long overdue update. I keep forgetting...
Anyways, there are some interesting things going on, check them out!
1) Replacing a water heater
Greif is looking to replace his water heater relatively soon and asks about some different possible replacements.
water heater - EcoRenovator
2) 5.5 kW solar array install
Michael shares with us his DIY install of a 5.5 kW solar array with tracking.
DIM 5500 w PV Array - EcoRenovator
3) Cooling with water
Charles asks about using cold / ground water to cool down his house.
cooling with water - EcoRenovator
4) Heat pump water heaters
Drake asks about heat pump water heaters.
Heat pump H2O water heaters?? - EcoRenovator
5) Ventless dryers
Daox asks the owners of ventless dryers about their experience with them.
Who is using a ventless (heat pump or condensing) dryer? - EcoRenovator
