Old 04-03-2013, 10:52 PM   #56 (permalink)
bazman
Weird Thing - '00 Holden (GM) Commodore SS Series II
90 day: 18.67 mpg (US)
Well, I got 31.24mpg from the 550hp LS1 on a trip under perfect conditions but no hyper milling. Averaged 100kph (62mph).
Sadly that is imperial mpg, so that translates to 26mpg US or 9.09L/100km. Still not as good as the stock cam but I am yet to install the new state of art Bosch EV14 injectors which should gain another 3-4% over the bored out crappy injectors I am now using as there are several areas where the tune can be improved with better injectors.
We are getting there :-)
It's not bad for a 4000lb 4 door sedan with auto. Figures are no BS dash reading, these are actual kms and actual fuel used topping up by sight to ensure same level at each fill up.
