Old 04-04-2013, 10:21 AM   #4 (permalink)
CapriRacer
Tire Geek
CapriRacer's Avatar
Neil,
You've been around here long enough to know that "LRR" is a relative term and doesn't mean great rolling resistance. It means "better" rolling resistance compared to other tires with similar wear and traction characteristics.
Put a different way, you can't get both super low RR and super long treadwear in the same tire. It's a compromise. So you need to decide what compromise works for you. Tire Rack is a good way to research this. - and the OE tires are most likely to give you the best RR, but if look at the treadwear ratings, they aren't so good.
CapriRacer
Visit my website: www.BarrysTireTech.com
New Content every month!
