Old 04-04-2013, 02:35 PM   #83 (permalink)
RedDevil
90 day: 55.39 mpg (US)
Originally Posted by johnathanf1lm View Post
I"m sure this was mentioned but a Prius has a CVT which putting larger tires doesn't do anything besides add weight since the CVT adjust the gear ratio constantly. Now if the Prius had a fixed geared trans like most automatics this would add weight but would make the gears taller. Long story short wrong car to test and prove the larger tire theory.
Personally, I've experienced otherwise.
A CVT can adjust the gear ratio between its limits only. If the optimum lies beyond that, tires do play a role.
Driving at a constant speed between 30 and 60 mph, my CVT is at its top range all the time; revs = mph times 30.
I bet the Prius, with its bigger engine, will also have no trouble doing that.
So tires with a larger circumference will drop RPMs in the 30-60 mph zone.
