Old 04-04-2013, 06:18 PM   #3 (permalink)
radioranger
radioranger
the more you coast , the less fuel, the less wear and tear on everything ,two worries , you hate to use your brakes on downhill runs, so you might speed a bit , and other drivers may tailgate you expecting to bully you along a bit faster, best thing there is to let them pass and enjoy the draft as it pulls you along for a bit , read the you might be an ecomodder comments funny and mostly true. I've also had police tail me since i go slower than the speed limit on the highway , they might think your impaired, had it happen !! probably not alone , but generally the less fuel you burn the longer your car will run.
