Thanks for the advice. I've heard that running a series wound motor without a load can cause damage, should I try to run it within a certain rpm range? Would you recommend placing some sort of filter over the inlets when I add fan cooling? Do I have to worry about water getting in to the motor? I plan to block off the engine bay as much as possible but some might still get in.
