Originally Posted by War_Wagon
Welcome. If the transmission noise is there when you push in the clutch, it's probably the throw out bearing. If the noise is there in neutral with the clutch out, but goes away when you push in the clutch, it's probably the input shaft bearing. Either way, start with checking the fluid in the gearbox, it's probably due for a change anyway, and new fluid might quiet things down a bit if it's the input shaft bearing.
thanks for the welcome! the transmission noise is actually only there during initial acceleration and seems to get progressively more mild as i go through the gears. i'll be swapping out the fluids all around here pretty soon, possibly this weekend so i'll definitely see if that helps. a lot of the recommendation's i've seen for the transmission call for amsoil 10w-40, your take?
