Old 04-06-2013, 06:53 AM   #3 (permalink)
NHB
Originally Posted by jeff88 View Post
2 Engines, each 1.8 liters:
- Engine 1: 4 cylinder engine (.45 liters per cylinder) (ex. 79x91.5 borexstroke)
- Engine 2: 8 cylinder engine (.225 liters per cylinder) (ex. 39.5x45.75 borexstroke)
In the end, you still have the same size engine, just the bore and stroke is exactly 1/2 the size of Engine 1 with half the cylinders, but double the size cylinder. I'm thinking this might be more efficient as more cylinders will fire per revolution of the crankshaft.
Any thoughts?
Engine 1 has 8 times the displacement of engine 2. In order to reduce displacement 50 % you need just to reduce displacement 50 %. Another option is to divide bore with 2^0,5
(79*2^0,5=59)
Fewer cylinders will give you:
  • Less surface area for heat loss
  • Fewer moving parts means less mechanical friction (pistons, con rods, valves...)
  • Smaller engine (one cylinder with 79 mm bore takes much less space than two cylinders with 59mm bore)
On the other hand, fewer cylinders mean:
  • More vibration
  • Uneven torque output (bigger flywheel)
  • Higher piston speed and/or mass (might be a problem at high revs)
The Following User Says Thank You to NHB For This Useful Post:
ChazInMT (04-06-2013)
