04-06-2013, 10:08 PM
bad idea
in a G10 advancing the cam at all is a very bad idea
it seems like it should be a good idea
but
it is not
the exhaust lobes get advanced along with the intake lobes
and the end result is that the exhaust valves close before the combustion gases can be expelled , before TDC ....
i had installed a +10 cam wheel from 3tech , every thing got worse
so i checked to see why
look inside the red oval that peak upward shows pressure where there should be no pressure
overlayed on the pressure waveform of the same engine without advanced cam timing
![](http://farm4.staticflickr.com/3478/3813586472_0188b47182_b.jpg)
this is how you measure it ... that fluke pv350 pressure transducer is connected to a digital storage oscilloscope either Pico 6 or ATS Escope .
learn from my pain
do NOT advance cam timing on any G10
