Old 04-07-2013, 07:52 AM   #100 (permalink)
CapriRacer
Tire Geek
CapriRacer's Avatar
Originally Posted by PaleMelanesian View Post
A certain major tire maker contradicts this.
Defender | Michelin Tires
Max load is rated AT the tire's max 44 psi.
Yes, I am aware of that, and I disagree with the way they state it.
Proof? I could show you the source documents, if that would help.
But an easy way would be to ask Michelin what the load carrying capacity of a particular tire is at 35 psi if the tire is a P metric, or at 36 psi, if the tire is a Euro metric. If I am right, then the answer will be the same load as published, showing that what they published isn't quite accurate.
- OR - you could ask for a load table for the particular tire. Either way, I am confident of what you will get back.
CapriRacer
Visit my website: www.BarrysTireTech.com
New Content every month!
