Old 04-07-2013, 04:27 PM   #18 (permalink)
JRMichler
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 43.95 mpg (US)
Originally Posted by Weather Spotter View Post
PCM vehicle power 4 – ignition coil Fuel pump relay? the issue with this one is that it cuts the fuel pump as well, this can lead to a long restart wait as fuel pressure is built back up. I would try to find the split to the fuel injectors alone and put the relay in there.
I THINK that a momentary contact kill switch would work here. Hold the switch long enough for the engine to coast to a stop, then release. Once released, the fuel pump should restart and pressurize the fuel system so everything is ready to go when bump started.
The Following User Says Thank You to JRMichler For This Useful Post:
UltArc (04-14-2013)
