Old 04-07-2013, 03:36 PM   #13 (permalink)
renault_megane_dci
la_voiture_de_courses - '03 Renault Megane Estate
OldContinents
90 day: 44.34 mpg (US)
xiao lan - '01 Audi A2
90 day: 38.88 mpg (US)
Brit iron - '92 Mini Mini
90 day: 45.5 mpg (US)
Prius - '09 Toyota PRIUS Lounge
90 day: 47.37 mpg (US)
Beemer - '06 BMW F800 ST
90 day: 53.06 mpg (US)
As far as throttles are concerned, I am planning on using drive by wire throttle bodies from cars (I know where to source some for cheap) so that I can have them operating separately.
I will probably need two single pressure sensor in order to balance the trottle plates on the run.
For the O2 sensor, I need to do some digging because it is not entirely clear if I can or not foul the ECU when running in single cylinder mode just by doubling the output of the O2 sensor to make the ECU happy about the amount of fuel he sends and the result he sees from the sensor.
