I picked up a new driver side CV shaft because the sunfire shaft did not fit the 4t60. The new shaft is from a 1994 grand am with a 3100. It dropped right in! Now all I need to do is replace the output seals, and input seal and it will be good to go. I can change the filter/fluid later this summer. Things are coming together.
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
