Old 04-09-2013, 06:05 PM   #10 (permalink)
jlspr
rusty - '94 Honda Accord EX
90 day: 35.13 mpg (US)
Originally Posted by some_other_dave View Post
You can check the t-stat by feeling the radiator hose. If the upper hose is warm to the touch after you've been driving a while, then the t-stat is open. If it's cold all the time, the t-stat is closed.
-soD
Do you mean the lower hose? Before the lower hose was cool and the top was hot. Now they are both hot. I'm wondering if the lower is hot from the temp under the hood. Its. It's not as hot as the upper is. Also would a stuck stat cause the fan not to come on? I haven't seen it come on yet since I've been driving the car. The sensor is right after the stat correct? So if its closed then it wouldn't know when to come on?
