Old 04-09-2013, 09:17 PM   #17 (permalink)
jlspr
rusty - '94 Honda Accord EX
90 day: 35.13 mpg (US)
The temp gauge reads normal. I flushed the radiator with water with both hoses off for a few minutes. I noticed some black pieces floating around in the antifreeze. Really small pieces. From what I'm hearing then it sounds like it is clogged up somewhere. How would it be clogged if I flush it with water and it comes out the bottom? Guess I will check around for a radiator. It was boiling over when it was cool outside. It hasnt boiled enough to blow through the overflow yet but I noticed there is more coolant in the overflow than before.
