Old 04-11-2013, 01:01 AM   #3 (permalink)
Enki
Enki's Avatar
If you're a purist, you're going to hate me for this.
302 LSX running E85, fed with twin TS EFR 9180 turbochargers. On pump gas, I'll have enough airflow at 8k rpm (which is where I'll set peak torque to hit at) for 1500 horse. E85 will be probably close to 2000, if I ever get brave enough to push the boost that high (35 PSI @ 8000 RPM).
