transmission rebuild kit is ordered as well as the shifter handle. im bidding on a shifter mechanism on ebay that goes off in a couple days. i got the 1/2 slider gear this week. taking the flywheel to the machine shop to get turned this afternoon. also got the clutch assembly. 10.4 inch disc. 10 spline. cant wait to get the trans done so i can start building the engine. couple guys on the amc forum are helping me out with picking an aftermarket cam that would be good for low rpm torque cruising. might do a 4.0 head swap too.
