with the torque converter fully unlocked my engine speed jumps to around 3000-3500rpm under load. At 3500rpm my ECU enriches the mixture. after some experimenting i managed to trick the TCU to keep the TQ locked using the throttle while increasing engine load to about ~95% at 1500rpm. you just have to slowly open the throttle, something to do with the drive by wire system. if you just step on the throttle (even if your only apply a bit of throttle) the torque convert will start slipping and RPMS jump. I found 1500rpm (TQ locked) and ~95% engine loads to give me best results but if anyone thinks i can improve on this to reach my 30mpg city goal please let me know.
