Oliver Kuttner writes on Facebook:
To clarify some of the publicity we are getting which misunderstood some of the points I was making: If we build a gasoline car it would likely be a 2 cylinder four stroke. I was referring to designs like ours needing to replace the 2 stroke low end cars often still sold in emerging markets.... , The base car with gasoline we are targeting $20,000.-- retail, as a hybrid or electric the price ail be in the mid to upper 20s. There is no creep to speak of in the cars. Now at 1400 lbs as a target for an electric or hybrid I believe that can be reached with all comforts you need and have come to expect. It is based on a metal car which means it is easy to recycle and lower in cost and can be made in large numbers.... . The front and rear metal frames were place holders to demonstrate the size and luggage space. The crush boxes are still in development. The beams holding the wheels are high so that the bumper structure defined by FMVSS in height can double to carry the suspension in order to keep aerodynamic efficiency and weight down. A gas only car will be lower mass. Top speed has not been decided upon but will likely depend on engine and performance choice. The cars should be able to do everything normal cars of today do... , Last, the current issue of Autoweek (Earth day) has an article written by a journalist who drove the chassis, hard... Work remains to be done but it will be the simplest lowest mass 4 seater on the planet and likely the most efficient car... And It will be fun. Thank you all, I thank my team, This car will be the originator of a new segment, created through a different and more efficient structural architecture with many possibilities.. If you want to hear more I will be speaking at the Tom Tom festival on Saturday, and on behalf of BASF at the SAE conference in Detroit on Tuesday.
New article.
https://wot.motortrend.com/350-mpge-...ok-354429.html
I try to be helpful. I'm not an expert.
