the Jetta is DSG = no torque converter
the jetta hybrid is DSG
so there is no torque converter
like is used in an automatic and will easily exceed 30mpg
the jetta has a "glide" function where the drivetrain is disengaged from the engine for a "Power on coast" type of function
the subaru ?
can be tricked (as you have discovered) as rate of change in TPS value is a primary input to unlock the torque converter
the only real fix to to replace the car with an automatic trans to one with a manual trans
