Gm diesels have an electronic pump mounted driver (PMD), it uses a resistor to calibrate the PMD to the ip pump #1-#9. Has anyone tried to see if there is fuel pump duration output that would work on the MPGunio? I want to purchase a MPGunio for my 1994 gm diesel truck.
Reason: Oops, missing info
