Old 04-15-2013, 06:03 PM   #12 (permalink)
Xist
From what I understand, Singh did this on two-stroke engines, but since four-strokes are supposed to be more efficient, then it might not do any good.
I do remember reading about one test. Someone said that it was not scientific because it used the wrong cell, but I doubted that the guy knew what he was saying. The testers said that proper testing would have been prohibitively expensive.
Okay, quick search results:
Thanks to ConnClark: RevSearch Engine Dyno; Grooves testing.
V8 without significant results.
The one that I described, which I shared in the same thread: Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Singh Grooves
The entire testing procedure took twelve months.
Mwebb shared this, stating that for a three-cylinder engine, grooves increase mileage without affecting performance: http://somender-singh.com/uploadfile...s_Analysis.pdf
He said that it would not work with more cylinders.
Well, try it on a lawnmower and get back to us.
