Originally Posted by AaronMartinSole
Take for instance the Seat Ibiza Ecomotive rated at 80.7 mpg,
or the Ford Fiesta ECOnetic rated at 78 mpg,
or the Volkswagen Polo BlueMotion rated at 74.3 mpg.
(I do believe those are imperial measurements, which would translate to: 67mpg, 65mpg, and 62mpg, US).
You also have to consider the difference in the mileage tests. The Euro tests give higher numbers than the US EPA test. It's not a direct percent change, it varies by vehicle, but the difference is in the 10-15% range I believe.
60 mpg, 58 mpg, 56 mpg are the most comparable numbers. The most efficient cars available here are two Prius variants, both rated at 50 mpg.
