Old 04-17-2013, 06:52 AM   #35 (permalink)
RedDevil
90 day: 55.9 mpg (US)
Originally Posted by PaleMelanesian View Post
You also have to consider the difference in the mileage tests. The Euro tests give higher numbers than the US EPA test. It's not a direct percent change, it varies by vehicle, but the difference is in the 10-15% range I believe. ...
It is even much worse than that.
My lifetime MPG on the Insight is 48.67 mpg (US) right now, which is about 20% over EPA and 5% below the manufacturers claim in Europe. A 25% discrepancy!
The European tests are done with a hot engine from start, perfect conditions and ultra smooth tracks, no lights, no A/C, no radio, no heat/ventilation...
I test drove a Seat Ibiza ST Ecomotive 1.2 TD 3-cyl one day. It had NO low-end torque under 2000 RPM. Don't grief for missing that one in the US... I was happy to buy something else.
A colleague of mine has its Skoda sister model as a company car and gets far worse mileage than I do on the Insight. To be fair, he doesn't try. Nor would he buy that car for himself when the lease contract expires.
