Okay, just found out last night that my timing might be off a tooth...I hooked up the timing light and was running very advanced at idle. It was off the tab, but I'd estimate between 25* and 30*.
I am going to pull it back a tooth tonight. I hope that this is the fix and the result will be a better running engine with more MPG's...
