Old 04-17-2013, 01:38 PM   #1 (permalink)
mozul
mozul's Avatar
Spitfire - '68 Triumph Spitfire Mk II
90 day: 26.18 mpg (US)
CivicHybrid - '04 Honda Civic Hybrid
90 day: 37.1 mpg (US)
Question Fuel Rate at Idle Question
I have a new UltraGauge and have been using it on my 2002 Jeep Liberty (4wd Limited Automatic) and on my 2006 Honda Odyssey (EX-L Automatic). I have noticed in the Liberty, if I sit at a light at idle it will consume measurably less fuel if i put it in Neutral versus in Drive. (~0.5 GPH in Drive vs ~0.4 GPH in Neutral) When I try the same thing on the Odyssey, there is no measurable difference. In the Liberty I don't have the AC on, but the Odyssey usually does have it on since the climate control is always on for my wife and kids. Could this be the reason or is there something else going on? On the Odyssey, the fuel consumption rate is a bit more "noisy" than on the Liberty, i.e. the reading jumps around a bit more.
Can anyone with more insight explain the difference between these two automatics?
