I do see a change in my Odyssey between D and N. However, as you observed, having the AC on dwarfs that change. Try running the air on Auto-AC Off for a bit next time. Also, the Auto ac system is smart and cycles the compressor on and off only as needed - if it's cycling you'll see jumps in fuel consumption to match.
