Old 04-18-2013, 02:33 AM   #14 (permalink)
cRiPpLe_rOoStEr
Originally Posted by War_Wagon View Post
I think the problem is if you use it for the windshield. Safety glass is made so it shatters into small pieces, so if you go through it it doesn't cut your head off on a giant shard. For motorcycles it gets a pass as the idea is you either go over it, or it snaps off the bike. Some of the fast street cars around here used to run it for the windshield to save weight, but that was reeeeally illegal. Like I said, I don't know about the legality of side or rear windows on passenger cars, I think it probably depends on where you are.
The pressure to break a plexiglass windshield is far greater than for a regular laminated windscreen. Also, the same plastic film used to retain shatters can also be applied to them.
