Old 04-18-2013, 07:10 AM   #27 (permalink)
sarguy01
sarguy01's Avatar
Mazda5 - '12 Mazda 5
90 day: 25.22 mpg (US)
Big D - '11 Dodge Durango Crew
90 day: 18.75 mpg (US)
Okay, before I even got to the timing belt, I realized that the crank pulley was on wrong! No wonder the timing mark didn't line up. I checked the belt anyway and found it to be correct. I put it all back together and timed the ignition. It was at 0*. The hood sticker said 5* and other forum member say 8* is best. So, it is set at 8*. If it is too much timing, I can always pull it back.
I have driven it twice since the adjustment and it does run better. I should say, it accelerates a lot better (But I really drive for MPG, so there isn't a lot of excessive acclerating anyway). Hopefully this will get me above the 40 mpg mark...now that it is running correctly.
