Old 04-19-2013, 04:32 PM   #4 (permalink)
some_other_dave
Miatas had 4x100 wheels, and they were pretty weight-conscious early on.
The center bore is another place that might or might not fit. If the wheel bore is larger than the part of the hub that goes into it, you would need to buy or make some adapter rings.
You also have to worry about offset. Do the wheels need to sit far out from the hubs, or do they sit way back in the fenders, or something in between? Will the new wheels sit in about the same place, and will the tires rub on the inner or outer fender, or on the strut?
Just things to be aware of.
-soD
