Old 06-20-2008, 03:52 PM   #1 (permalink)
Smog
Tacoma - '06 Toyota Tacoma 2wd access-cab base trim
90 day: 32.03 mpg (US)
idea : DIY Fastback top for pick-ups
Hi everybody,
just an idea for DIY fastback top for your pick-up.
a lightweight EMT tubing frame (available at HomeDepot)
then recover with ....
..... Boat shrink wrap !
it's not expensive, it's lightweight, it will resist UV, can be replaced if torn by a little punk and no seams. most are 6 mils think but you can add layers for a tougher top.
I may give it a try on my 2006 toyota Tacoma (2wd access cab 4 cyl). but the 7.5l/100km (32mpg) I have right now is hard to beat. (was 8.2 with the fiberglass fullsize top).
