Old 04-22-2013, 02:50 PM   #72 (permalink)
pascal28
Well, after a good night's rest and a fresh look at the tuft testing results today, I've decided it's good enough as-is. I'm not going to change it.
EDIT: Neil, I might just test that wheel strake/boattail idea to reduce turbulence, too. If that doesn't help, when I make the permanent tail, I'll use a little less curvature in the sides, which will add about 20 cm / 4 in. to the width of the rear.
Next task: A-B-A test and weather-proof it. Weigh it, measure it, to answer those inevitable questions.
Many thanks for sharing the results. This is just what we need to help understanding.
As you mentioned the current curvature on the sides is not ideal. Do you have a picture of the boat-tail from above & (ideally) the angles used? This will help determine what angles to not exceed.
