Old 04-22-2013, 07:39 PM   #8 (permalink)
freebeard
They are 14x5.5 high offset 4x100 bolt pattern. I would like to find cheap alloys without a manufacture label.
Do you mean no visible logo? Centerline forged aluminum wheel with a Moon spun aluminum wheel cover.
Here's a general discussion of the subject: Light vs. Heavy wheels
Is your tire outside diameter a little less than 26"? Then you could use these, the next tire I want to buy. Tire weighs about as much as steel, but more than aluminum; so these on a light rim would give the least unsprung weight.
