Old 04-23-2013, 02:30 AM   #7 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Originally Posted by Josh8loop View Post
I am also thinking of insulating the oil pan(just like Mercedes and newer VW's do). I am trying to figure out an easy to work with(flexible) insulation that doesn't shed significant amount of fibers. Anyone have any suggestions?
I just started insulating my oil pan with a rubber foam. It is used for sound deadening and I got it from a car audio store. It is 3mm thick and the specs say it will handle -40 to +105°C (-40 to +220°F).
Hopefully it will not only keep the engine temps higher while running, but also keep the oil warmer after parking, and make better use of the oil pan heating pad.
