Okay guy's I am back! Sorry it has taken me so long to get back to you... I have had more stuff come up than you can imagine.
But it's all good! I spent around $800 and had the transmission of fully rebuilt. Within the next few weeks I will be getting a check for $1200. So here's the plan. I want to swap in a lean burn d15.. As a way to keep the cable clutch I could stick with a HF trans, I found one for $300 and a only 95,000 miles.
But I don't know what all I need... most ppl do the opposite of this swap.. Will I need anything other than the motor, trans, Factory Motor mounts engine wiring harness, PO 7 ECU. And factory axles?
