Originally Posted by cbrer
... So I'm assembling the following parts to try and get better fuel economy, and drivability. Along with raising up tire pressure to ~50 PSI. Electric fan and controller. ... My question is how much MPG can I reasonably expect to gain with these changes?
Welcome.
It depends on what the tire pressure was. 50 is already quite high; the harder the tires get, the harder the suspension will have to work on a rough road, so what you gain in tire rolling resistance might get wasted in the shock absorbers.
Going from 28 PSI to 50 will help a lot.
From 45 to 50 may not help mpg at all if the road is not smooth.
The fan will help a bit, but it will take some time to gain back the cost of the swap. Given the mileage it may just not be worth it.
A good service may help a lot, get the wheels aligned properly etc.
Most of all: Steering wheel nut tightening. See the 100+ hypermiling tips.
Keep a fuel log. Get a tool for instant MPG readout. As you've been lurking, you will know this already of course.
