Old 04-25-2013, 11:54 PM   #9 (permalink)
oil pan 4
You can put a number of holset turbochargers on that cummins with nothing but off the shelf parts and adaptors.
First you have the turbos inlet, most holsets use 4''.
Most holsets use the T3 exhaust manifold flange, you exhaust manifold will work with most of holsets. Some HX40 turbos use the T4 flange.
Most holsets use a 3'' down pipe flange there are some 4'' and a 3.5''.
