Originally Posted by MetroMPG
You probably know that 75 is hurting a fair bit (but not enough to explain 22 mpg).
Aside from the speed, sounds like it could be a really mpg-friendly pattern.
It'll be interesting to see what happens after the O2 sensor.
Yeah, I will have to post my results after I change them and reset my ecu. I know 75 is a bit fast, it will take time for me to learn to slow down.
I did just inflate my tires today to 45psi (the max pressure according to the sidewalls) it was at 35psi.
