I know your drawings & such are all preliminary, but you may want to consider the template overlay as guidance for the top curve. Also, if you are going to leave the bed intact, you probably don't want to bring the sides in drastically as this will create 2 areas of high pressure differential in close proximity that could hijack any aero gains you would otherwise achieve.
Hope this helps.
