Originally Posted by MPG_Plus
oversquare rules of thumb
What use of the term "over square" are you talking about?
Why "Over Square" Is Good
To me, over square means that the bore is bigger than the stroke. Which makes it a higher revving engine with more peak power output. Under square engines such as the new Honda NC700X have a stroke which is longer than the bore. Which moves the power band and redline lower for better fuel economy at the expense of peak power.
