I had an mpguino that was wired in at the points on the ecu, they did not want to stay and it was extremely difficult to reinstall the ecu. so I gave up and just found the diagram online and took the ecu out found the wires, marrked them with tape and then found them on the harness in the engine bay. checked the injector for power. from left to right its the second one. the vss was on the driver side by the brake master cylinder(yellow and light blue I believe) and the most difficult to locate. then just find a ground and a power source and you are golden. Well not really because you still have to snake the wires through the firewall. You can just use a hanger . its located by the battery. then snake those wires to where you want the MPguino to be. I took pictures of mine and will try and post them now if the site will let me.
Reason: pictures
