Old 04-28-2013, 08:17 AM   #1 (permalink)
mistareno
LPG (propane) Turbo club car
G'day from Australia. First post here but I have been reading the forum for a few years.
I have a 1985 Renault Fuego that has a Renault 21 Turbo engine on straight LPG (propane). It has a few other goodies and makes about 250hp and produces less CO2 than most new cars.
Being French, it is basically made from aluminum foil and chewing gum so weighs under a 1000hg.
I am starting to look into some aero mods that will hopefully improve the drag/lift ratio.
I have a reasonable idea on what I hope to do, but there are a few question that I'm hoping someone here might be able to answer.
I have fitted a long deck style spoiler to the lengthen the car and increase the seperation point. It is similar to the RX7 image below (sorry can't link to pics) but with a smoother less defined gurney flap on the back.
bodykits.com/productImages_thumbBIG/e67d4f87_6872.jpeg
I don't really expect the spoiler to produce downforce, but I want it to create a low pressure underneath to allow the underbody aero to work better.
I was going to fit a 6 inch or so splitter to the front for some downforce and flow diversion to the cooiling system and have the splitter continue to a flat floor with some rubber flow guides around the front wheels.
I was going to seal up the usual cooling exhaust paths around the front wheels and instead use the largish area between the chassis rails and the flat floor (where the tail shaft is on a rwd normally) to duct the cooling air from the radiator to the rear of the car and eject it above the diffuser into the low pressure area under the rear spoiler as wake infill. (think P51 mustang style but alot longer...)
The flat floor will continue to a diffuser at the back. I don't want it to be too obvious from behind, so the strakes may not be as tall as optimum. I'll see how that goes.
The main question I had was to do with the front guards (wings)
I was going to flare and open up the back of the front guards to allow the high pressure air to escape and flow along the car (like the starion below)
1.bp.blogspot.com/_WzKgbcefvdk/TKtKlcT-K0I/AAAAAAAAACk/L3nzUN1F9ig/s1600/wide+body+starion.jpg
Has anyone tried this? Did it achieve the desired results?
Was water and debris spray a problem?
I was going to run some mesh in the cavity but don't want a huge ploom of spray every time it rains.
Any feedback on the rest of the plan?
