Old 04-28-2013, 03:48 PM   #27 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Originally Posted by mikeyjd View Post
It was getting a bit on the warm side today so I opened about 10% of the grill in the middle bottom section. After that it was holding slightly warm but doing well.
If the grille block is affecting the final coolant temp (after warmed up) at all then you've overblocked it. You want the thermostat alone to determine the final temp. If it isn't you may not be doing any damage (yet), but you're playing with fire because the thermostat is wide open and you can overheat in a hurry if you're not careful.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
